ttmott avatar image
ttmott asked
Multiplus CCGX Automatic Generator Start Sequencing
When the generator is started and running manually and not started by the CCGX AGS will the CCGX shut down the generator when battery charging complete? If I'm running the generator using the manual start switches I do not want it to shut down automatically by the CCGX.
Thanks
Tom
Hi Tom, have you already studied the documentation? https://www.victronenergy.com/live/ccgx:generator_start_stop
ttmott avatar image ttmott commented ·
I did and studied it again to make sure I didn't miss something. As a clarification the "manual start" is existing switches on the boat and I'd rather continue to use those and/or the GX (they are in different locations on the boat). I do understand the manual start feature on the GX will override any automatic features. Maybe no choice here....
Could I possibly use the detect AC1 as a do not start or shut down trigger? The boat could be on shore power or generator and AC power would be active at the inverter in these cases.
Thanks
Tom
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ ttmott commented ·
Hi Tom, ah I understand better now. I thought you meant the Manual start feature on the GX.
For when started manually on the generator itself: how that works depends on how its all wired and what type of generator you are using.
In most cases I would think that indeed it works like you want: the generator then has a three way switch: On/Off/Auto.
In which Auto means ”listen to the GX device”
