cochonpentu avatar image
cochonpentu asked
SmartSolar MPPT 100/20 - load current too low
Trying to install a small off-grid solar system for an academic research with my minipigs ;-)
Monitoring the power produced via the VictronConnect app tells me something is wrong but I can't seem to be able to troubleshoot it myself. The power is jumping to about 10W once in a while and then drops to 0W. Current shows mostly 0.1A. Attached are all Trends screenshots from the Victron app. Can someone please help me?
My installation:
Solar Panel from Solarex (Pmax 53W // Imax 3.08 // Vmax 17.2)
SuperWatt Gel 200 Ah 12V
Thanks a bunch!
Mitch!
(you can my minipigs on IG: @cochonpentu ;-))
MPPT Controllers
JohnC avatar image
JohnC answered ·
Hi @Cochonpentu
I think your mppt may be (at least partly) disconnected from your batteries. Check your wires/crimps/fuse/isolator/etc.
The clue to this is the batt V jumping around significantly with just the 0.1A of current spike. It wouldn't do this with 200Ah of batt attached.
The multiple attempts is possibly because the mppt needs 5V of headroom between Voc and Vbat. But it's not getting the real Vbat, just the V from it's own output terminals (which isn't stable).
cochonpentu avatar image cochonpentu commented ·
@JohnC: Thanks a lot for your great help! I disconnected everything and reconnected it all and it seems that the issue is now resolved.
All the best,
Mitch.
kevgermany avatar image
kevgermany answered ·
Please attach the MPPT settings as well.
Is it winter where you are?
Thanks @kevgermany! It seemed the issue was caused by faulty wiring. I appreciate your help!
Best,
Mitch
