gharshaw avatar image
gharshaw asked
/Ac/Alarms/GridLost is not in the DBus on CCGX
@mvader (Victron Energy) @Scott Bender
I'm attempting to create a pushover alert with NodeRed using the Victron System node. The Dbus path: /Ac/Alarms/GridLost is missing in the node as well as on my CCGX 2.80~33 (missing in dbus-spy). I do have "monitor for grid failure" enabled on the CCGX.
Scott, I saw that you made a change in the scripts/missingpaths.json to "add support for /Ac/Alarms/GridLost". Maybe you have a suggestion as to why the Dbus path is missing?
Appreciate any help
Thank you
Node-RED
gharshaw avatar image gharshaw commented ·
Any thoughts on this issue ?
Thanks
Hi @gharshaw , you found a bug in the nodes: this functionality was moved to a different D-Bus service a long time ago (v2.60 I think).
We'll update the node. The right path is com.victronenergy.vebus.[something] /Alarms/GridLost
Its no longer under com.victronenergy.system.
We'll fix that. Thank you for the report!
