bernice avatar image
bernice asked
MultiPlus II GX parallel connection
Hi Victron Community!
I want to connect two MultiPlus II GX in parallel.
How can I disconnect/deactivate one GX?
When looking at this Quattro connection below, how can I connect and set the system that the priority is PV, battery, Generator, then grid and if there is load shedding then it will be PV, battery, generator, then grid.
Please share MultiPlus II GX parallel connection schematic.
Any answer will be appreciated.
Thanks
Multiplus-II
You have to open one of the MultiPlus and then you can disconnect the GX module from power and VE.Bus.
