vintdiesel avatar image
Multiplus II 3000 GX backlight
Hi there,
The Multiplus II 3000 GX manual states in section 7.2 that: "When the GX Card is on, pushing the button beside the screen will activate the backlight. The backlight will turn itself off after 5 minutes".
The backlight on mine is always lit from power-up, whether I use the push-button or not, i.e. the backlight never turns off.
multiplus-ii gx
Izak (Victron Energy Staff) avatar image
The backlight doesn't turn off, it just dims. Does it at least go brighter when you hit the button, and dimmer again after some time?
Share
