j1976 avatar image
j1976 asked
Multiplus Compact only work with AC input
I have a issue with a Multiplus Compact 24/1600 inverter. I checked the inside fuse of 150A and no problems there, 24vdc arriving to the inverter, but none of the leds light up, no output and no access through MK3-USB. Having the AC input with power, the Multicompact starts with green light, then goes to orange (meaning it´'s charging), and i can access the configuration with the MK3-USB. Theres anyway to disable the inverter with a wrong configuration or firmware update? Or the problem is purelly electrical? (i checked inside and there is no signals at all of burned components. Thanks in advance for any help.
Multiplus-II
11 comments
snoobler avatar image snoobler commented ·
Hate to state the obvious, but isn't there a switch for OFF, ON and CHARGER? Are you certain the unit is ON?
j1976 avatar image j1976 snoobler commented ·
would be wonderful if was that. i avoid to mention the most obvious to don't make the post too long :)
Paul B avatar image Paul B commented ·
Some screen shots of the VE.Configure setup screens - and what firmware is the unit currently on.
a factory reset is done if you load the latest fw using VE.Flash
To me its sounds like the fuse is blown inside - I know you say its not - but replace it or do a bypass of the fuse as a full test
jwfrary avatar image jwfrary Paul B commented ·
Is there a GX device which is set to charger only?
j1976 avatar image j1976 jwfrary commented ·
Its possible to disable the charger capability in the MultiPlus Compact... maybe the inverter could be disabled aswell...
j1976 avatar image j1976 Paul B commented ·
I will try it anyway. but I have 27Vdc after the fuse. I will also check the firmware.
thank you
marekp avatar image marekp j1976 commented ·
Volts after the fuse can be misleading.
Important thing is whether current flows through this fuse.
j1976 avatar image j1976 marekp commented ·
I will replace the fuse and try it. Second time it´s refereed on the answers. Thanks
I had made a shunt on the fuse, and nothing change. Any ideas?
Paul B avatar image Paul B j1976 commented ·
You may have, but that dose not mean its there under load - its a easy test to do
thanks for your attention
j1976 avatar image
j1976 answered ·
This happen after my client run a configuration on VEConfig to create a 3phase system (he has 3 Multiplus 24/1600). after that two of them have this problem, only one (i guess the one that was config as L2) is working properly
Guess your client needs to get all the configuration parameters from all three units back to you so you can see what they did.
