I have 2 controllers that I over loaded with to many panels creating to higher voltage for the unit. I was given the wrong information about the panel set up.
the controller units no longer work. I disconnected all power to reset the unit as the manual discribes.
After that I received more info about panel set up and loads.
I change the panel voltage input to the correct amount of panels to suit controller.
I plugged it all in and the controller doesn’t work.
As I switch the breakers on I lose all voltage thru the system.
is there anything I can do to get them working.
Any help would be great.
