palom170 avatar image
palom170 asked
How to configure gx with external current transformer.
Dear victron community, I have a system as the picture shows( grid parallel) . All loads are on AC in and the grid inverter too, is it correct that I need to set the fronius inverter on the gx device in AC output position to calculate the loads correctly? On the gx display loads and inverter are in ac out, but they are in ac in physically. I want to use the current transformer because the response is very fast with high loads. Thanks in advance
Multiplus-II
