mark-rolle avatar image
mark-rolle asked
BMV Relay operation multi devices
Can i run multiple remote on off connections in parallels off the BMV712 smart relay output
I want to switch off all mppt devices and an Orion dc/dc if ever and when battery reach's 14.5v as an added level of overcharge protection....it appears so??
BMV Battery Monitor
Hi @Mark Rolle,
yes you can. But take care and ensure that you don't exceed max. load capacity for the relay which is 60V/1A. You could use a low power relay (for example Optokoppler) in between to be on the safe side.
mark-rolle answered ·
Stefani i have hooked up as i asked and it works with the 2 x mppt 150/70 nsmart but as soon as i plug in an orion it closes circuit to all when it was open....seems i will need the relay to work the orion input....thanks
Maybe you have still the bridge connected in the remote on/off on the Orion?
mark-rolle avatar image mark-rolle Stefanie (Victron Energy Staff) ♦♦ commented ·
Not sure why it wont work but what does work is using the programable relay of one of the 150/70 to turn off orion at set voltage....thanks
