Rafa Gómez avatar image
Rafa Gómez asked
Set up a generator set - Victron Multiplus II
I have a solar installation at home with the following components.
I have a victron Energy MultiPlus 2 inverter 48 volts 5000 volts amps and 70 amps, I have two smartsolar chargers and a Venus GX.
The batteries are charged with 14 plates of 450 watts. 8 pylontech batteries of 2.4.
Currently I am low on charge in the batteries so I bought a Redstone genset with 3000 nominal power 3300 maximum power.
The genset is simple, it does NOT have automatic start (I have to start it manually)
General
Grid
Inverter
Charger
Virtual
How should i have the settings done?
Thanks a lot.
victron
anrich avatar image
anrich answered ·
Hi Rafa,
Have you read the generator FAQ? If you have followed the suggestions in the FAQ, which problem are you experiencing?
