Oluwatobiloba Adedeji avatar image
Oluwatobiloba Adedeji asked
Failure: Multiplus 24/3000/70 Not Powering - All 8 led flashes once
My installation composition is:
- Multiplus 24/3000/70
- Cerbo GX
- Lynx power-in
- Lynx shunt VE Can
- Lynx distributor
- Smart Solar 250/85
On installation, unit worked for some minutes but later started a low battery alarm on vrm, restarted after the low battery notification, minutes later or switches off finally.
Battery is lithium and voltage is 26.8. Reconnecting, the unit flashes all 8 panel led once and nothing happens. Same symptoms with Ac-in.
Paul B avatar image
Paul B answered ·
you can download a app called victron toolkit and this app will tell you what the flashing LEDs mean - at the moment from your description it says its a bootloader issue.
normally I would try reinstalling the inverters firmware - but maybe it would be better to contact your dealer or take it back to them, to test
This isn't covered in the toolkit. It's pretty basic and a pain to use.
