baz-spicer avatar image
baz-spicer asked
BMV700 suddenly only showing 100% SOC and around 2 amps
Hi, my monitor has been working fine for 3 years but has suddenly stopped showing the correct SOC, it’s always 100% even when the battery (lithium) was discharged. it also only shows around 2 amps regardless of any current draw or charge, day or night (I have a solar system).
Having read other posts I’ve done factory resets and reset the charged voltage to 14.1, also reduced the tail current to 3, but to no avail.
Any help greatly appreciated as I’m living in my camper and need everything working.
BMV Battery Monitor
Alexandra avatar image
Alexandra answered ·
@Baz Spicer
Have you tired to do a zero current calibration?
Disconnect all loads and charging sources, then hit zero current in Victron Connect app.
Also switch off start battery syncronised to 100%.
baz-spicer answered ·
Thanks for your reply Alexandra.
I’m a novice - what do I disconnect from where please?
Also I don’t have a Bluetooth connection to the BMV700 so can’t use the app.
i should also add that the voltage is showing as 0.00v.
What puzzles me is why it should suddenly stop working when until recently it’s been fine.
@Baz Spicer
Time changes the weirdest things in set ups. Thats why inspections are needed.
The shunt has a battery and a loads/charger side.
Disconnect everything from the loads/charger side. If it is still showing a current draw then it needs to be calibrated. If it does not then there is a gremlin on the wiring.
