Can someone please help me with the Victron Smart Shunt Bluetooth app settings for my battery specifications?
You may have to tweak these a bit. There is a video that runs through the basic settings. Check out the bmv 700 and 702 videos on victrons you tube channel if you want to learn more about the principles of how it works.
But initially looking at those specs, I would start with... Depending on what you have set on your charging sources, so sharing those will help us help you more.
My biggest confusion is the "Charged Voltage"... You have it as 13.6.... Victron state to have it .2-.3 below charge float (13.6), which would be 13.4 charged voltage?? But many forum reading, people are placing it higher to 13.9-14.0....
From my specs above... can this be better explained on what is the best Charged Voltage setting for my battery
Regards
35 People are following this question.
