Firmware old 2631490, new 2634490
More precisely: the electronics of a Quatro that was operated in parallel with a second one broke (firmware 2631490). The only replacement I get is the Quastro with firmware 2634190. What can I do to let the two devices run in parallel again?
The first four numbers (hardware ID) have to be the same.
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
Can I cange the firmware from 2634XXX to 2631XXX?
It seems that the differenc ar only the relai.
48 People are following this question.
