dub042 avatar image
dub042 asked
Multiplus self consumming
Hello,I have just Multiplus 5000VA, 48V. The battery are charging with other MPPT devices. Multiplus is set up as UPS,but charging is disable, and AC input is ON just when battery is too low, or inverter is in overload.
In inverter mode works OK, If the battery is too low, AC IN switch goes ON and Multiplus works without battery consumming ( battery charger is disabled). In this mode the self consuming is more than 100W, I dont know why.
VE config shows 132VA on input and 77VA on output, but on output is nothing connected.
Can someone explain it to me?
Thanks a lot
