tonithiele avatar image
tonithiele asked
MultiPlus 48 V Questions
i've a few questions about the Multiplus 48V inverter / charger.
* Can i change the gasing voltage ("Gasungsspannung") ? Mainly i want to switch between constant current and constant voltage charging. So i cloud imagine, if change the gasing voltage and i can switch between this two modes.
Is ist possible?
* Can i change the charge current direct? -> (via interface) ?
* Can i change the discharge current direct? -> (via interface ) ?
* Can i swicht between charge and inverter mode with a relais contact?
* What is the important difference to Multiplus II ?
I hope somebody can help my ;-)
byby
Toni
