bargeman avatar image
bargeman asked
Lithium and Multiplus compact
While looking for something completely unrelated in my MultiPlus Compact (24/2000/50) manual I realized that there is no default lithium charging option on the dip switches. While my 5 year old agm 340 ah house bank is working just fine now, sometime in the near future I'm going to be switching over. What am I gonna have to do?
Buy a MK2 or MK3 Interface and use VE.config to set it up for lithium.
marc-kermoam avatar image
marc-kermoam answered ·
Hello Matthias, regarding your answer, it seems that we don't need a password to set the option "lithium" in a multiplus 12/2000/80.We need only to connect a MK3. could you please confirm ?
Thanks
Best regards
VE.config only asks for a password if you want to change the grid code more then once, all other settings are not password protected.
kalusta avatar image
kalusta answered ·
I have a Victron Multiplus Compact and understand that I can program it via MK3 to fit with LIFPO batteries. How about the second DC output - can it still be used to charge a Lead starterbatterie or are the charging profiles the same for both DC outputs?
Thanks,
We had that topic a few times lately.
The trickle charge is not a second charging output it is just a connection to the main battery via a transistor.
The connection is always active and will drain the main lithium battery into the lead starter battery due to the higher voltage of the lithium battery.
Anthony Kirkby avatar image
Anthony Kirkby answered ·
I have just changed to Lithium and have the VE bus to change the settings. I cannot do so as it is calling for a password!
