tonithiele avatar image
tonithiele asked
Fancy MultiPlus InverterApplication
Hi everbody,
i want to realize a fancy Multiplus (with Cerbo GX or Venus GX) application :
DC-Side: 48 V Zebra Battery with self developd BMS
AC-Side: 400V AC common grid
Moreover: Parallel to the Inverter will installed a Car-Carcharging Wallbox.
If not car plug'd , battery should permanent hold in charged stage
If car plug'd and charge -> Wallbox should switch the inverter (digital input) to discharge mode and signal the value of dischargecurrent (CAN / Modbus [which is the best???]).
This
Here my questions:
Zebra-battery is not a Lithium- or Lead - battery. In the maunal of multiplus i read about 4-step - charge-procedure.
* Can i change the gasing voltage ("Gasungsspannung") ?
* Can i change the charge current? -> (via interface) ?
* Can i change the discharge current? -> (via interface ) ?
