southace avatar image
southace asked
Skylla ip65 70 amp (3)
The default factory setting on the 3 outputs of charge absorption volt are 1)14.4
2)14.8 , 3)14.8 as my battery banks are all the same they all require 14.4 absorption. I’m not sure if someone has messed with the settings but for my life I can not seem to change each individual output to 14.4 volt.
can someone please walk me through the setting to access reducing the volt to bank 2 and 3?
charger
The one setting is for all three outputs.
You can't configure each output individual because there is only one big charger inside not three.
southace avatar image southace commented ·
OK So why would 2 and 3 outputs say 14.7 and the 1 output says 14.4? I’m worried 14.7 absorption rate will cook my battery’s
