senorsally avatar image
senorsally asked
Goal zero yeti with victron no solar watts
I have goal zero yeti lithium, I have just connected the victron 100/30 charge controller, I am not getting any wattage or seemingly no solar input.
I simply swapped charge controllers and the previous one was working, so all the wiring should be okay and fuses too.
Any ideas as to why I am not receiving solar?
MPPT Controllers
Can you make some pictures of the installation and some screenshots of VictronConnect?
If you see 0V PV at VictronConnect check the polarity of the PV wiring.
4 comments
senorsally avatar image senorsally commented ·
image.jpgImage Caption
What the app shows
The settings page in app
Matthias Lange - DE avatar image Matthias Lange - DE ♦ senorsally commented ·
Take a look into the manual of the battery, I think the charging port where you connected the MPPT is designed to connect the PV panels directly to it.
