First thing I'd do is eliminate RPi issues.
Fit an RPi UPS shield with 18650 cells.
Not sure what the options are, but set up some logging to monitor WiFi, internet and the Victron data. Cos at the moment you've not got enough info to go on.
And how would an issue with the buck report a 1/2 dozen parameters consistently, and only 1 intermittently?
How would monitoring wifi change things, (assuming there could be a wifi issue) as the directly wired screen does the same thing?
You said VRM stopped working. I assume that's getting fed via WLAN and internet. Sorry if I misunderstood.
Pi via buck boost - if you're powering the Pi from the batteries you're monitoring, it eliminates this.
Really I'm second guessing what you're doing/how it's set up because you're not giving us much to go on.
I did not say my VRM stopped working. I said, ONE parameter, battery SOC, stops reporting after a varying period of time. An RPi power cycle fixes that, for another varying period of time. All other parameters report consistently and always. The SAME thing happens on the directly wired screen. So that eliminates (in my mind) wifi or VRM
If you are suspecting power supply issues, help me understand how that effects only ONE parameter, and not ALL parameters.
And... let me know what more info you need to further help diagnose. I will provide it
Power supply issues are out. 3 hours on the power bank, and same scenario
If the Pi is getting some data from the battery monitor the serial connection or the Pi isn't the problem. Sounds like the shunt/BMV fails after a few hours? Weird problem.
I have an extra cable. I think I'll try replacing the shunt cable to see what happens
SOLVED... I think
I changed the USB/serial, and once changed, I plugged the USB into a different Pi port. It has run 24hrs now without a hiccup, when before it was only running 2 to 4 hrs
Not sure which of the 2, or maybe both... or neither.... made the difference. More time should tell
Update... not good @#$%
Everything has worked from my last post on Dec 04 to now. I have the same but different issue. Before and now the RPi was not reporting battery SOC.
NOW the SOC is not showing on Victron Connect either! The SOC was showing in the VC app before
Do I have a bad smart shunt?
41 People are following this question.
