nicetrip avatar image
nicetrip asked
Orion 24/12 none isol. makes fizzling noise when switched on
hi, I am charging 400Ah lifepo4 through an Orion 24/12-70 none isolated. When I connect the load side or when the electronic battery isolator switches the Orions input 24V on with 12V connected, it makes a sound like something would melt away inside. Is this normal? No smell and it works so far.
Also the 24V input gets pulled down so much that the electronic battery isolator before the Orions 24V input disconnects and reconnects a few times. After a minute or so it stays connected and the Orion starts charging. Previously I had a Redarc DCBC 40A with 12-30V input and that one did not irritate the isolator switch.
Does anybody has the same experiences with battery isolators inline with the Orions and that sound?
Orion DC-DC Converters not smart
kevgermany avatar image
kevgermany answered ยท
I have a 24/12 , non isolated, non smart, but lower current. It's completely silent.
Sounds faulty. Contact your supplier. Don't use.
nicetrip avatar image nicetrip commented ยท
Hi, thanks, do you have one installed? Are they completely quite when switched on?
0 Likes 0 ยท
