arstegmeier avatar image
arstegmeier asked
Two Quattro 5000 running 180 split, trips GFI on shore and gen power
I have two Quattro 5000 in 180 opposed 120 amp configuration. When I hooked up shore power for charging, in trips the GFI. I removed the GFI from the circuit as part of trying to figure out a solution and it works a little. Only the main will charge.
With my generator, I can’t disable the GFI, so it trips the GFI on the generator and I can’t get it to charge.
Any help would be appreciated.
Generator
