charmcityboater avatar image
charmcityboater asked
Isolation transformer wiring question
Simple question. I am installing an isolation transformer and a 12/3000 multiplus charger on a sailboat. I assume the isolation transformer gets installed first, right after the shore power cord and ELCI breaker then the multiplus correct? I ask because I had seen some diagrams that show the isolation transformer wired after the multiplus on the AC output side of the multiplus.
looking for confirmation.
thanks
phil
Isolation Tranformer
hjohnson avatar image
hjohnson answered ·
Isolation transformer goes between your shore power connection and any other electrical connection in your system. The whole point is to eliminate the DC electrical path between your marina and your boat. You do not want your prop or keel to become the main grounding conductor for the marina!
ftlsailor avatar image
ftlsailor answered ·
I just want to add some other questions. If we are less than 10 feet from the shore power inlet, we do NOT require an ELCI on the shore side of the isolation transformer, right?
Also, should there be ANY breaker between the shore power inlet and the isolation transformer?
Ricky
christern avatar image
christern answered ·
As I have understood the ISO13297 it requires the RCD to be at a max cable length of 3 meters away from inlet. If the ELCI is equal to an RCD then it should be right.
I haven’t seen anything stated on breakers between inlet and the IT. Haven‘t looked for it either.
