André Vorster avatar image
André Vorster asked
Multiplus2 low AC output frequency.
While browsing through my recently installed 48/5000 Multiplus 2 (230V50hz) stats on VRM I noticed that the AC output frequency is low and out of spec.
The installation is a stand alone installation and the inverter supplies my home with power during grid power outages via a change over switch.
The output frequency is low from switch on with new and fully charged batteries, through varying loads.
Has anyone had a similar issue.
frequency
Alexandra avatar image
Alexandra answered ·
@AndreV
This happens sometimes when there is a mixup in wiring somewhere.
Especially if there is a neutral issue. Or the inverter is feeding back into itself somehow.
Paul B avatar image
Paul B answered ·
More info is needed here. The multi plus looks like its been outputting 50Hz fine
However if you connect to the mains or a generator the the unit will change to match the incoming frequency and then if its two low or high it will then disconnect from the mains/grid and start inverting again, please show the incoming vrm AC graph for the same time period,
André Vorster avatar image André Vorster commented ·
Hi Paul thank for your reply please find comparison.multi-in-out-comparison.png
André Vorster answered ·
Thank you for your replies and assistance. Herewith input verses output snapshot. Regards.multi-in-out-comparison.png
