Stephan Zillikens avatar image
Stephan Zillikens asked
Victron: frustration anytime anywhere
this forum shows how many users do not get along with the Victron system. All these users have chosen Victron because this system promises reliability.
But there is no transparent structure for the user to implement his expectations to the Victron system.
As an electronics designer, I know about current, voltage, the Ohms law and parameters, but after two months I still have massive problems configuring a system that consists solely of three Victron components and a Pylontech battery to do what it is supposed to do, provide stable and reliable AC voltage.
In doing so, Victron has all the tools in place to minimize frustration with the system from the start.
Why doesn't Victron provide a list of the different applications with the appropriate configuration files.
The first list asks what the system should do:
Power a motorhome
  1. Solar
  2. Alternator
  3. Power from the mains / limit mains power
Supply a boat with energy
  1. Solar
  2. Alternator
  3. Power from the mains / limit mains current
  4. Start generator AC-DC
  5. Emergency reserve/
  6. second battery
Safely supply a system with power
  1. Batteries in standby
  2. Buffer batteries
  3. Start a generator AC-DC
Power a house with solar or wind
  1. with/without battery
  2. with/without grid feed
  3. Limit grid power
  4. with/without grid charging the battery
  5. Start generator AC-DC
extend one phase network to three phases
There are certainly more applications...
One could assemble online one's Victron components needed for the tasks formulated above
One could automatically generate the appropriate configuration files for the formulated task and load them onto the components.
Translated with www.DeepL.com/Translator (free version)
Multiplus-II
nickdb avatar image
nickdb answered ·
To be fair, most of the people coming here do not realise this is a community site, they also, while knowing a bit about electricity, tend to know nothing about the products, with little to no training, buy online and don't get expert help to design and install. It is expected that everything is plug and play and when it isn’t, They then come here and moan about the product.
While no product is perfect, the majority of complaints here are self-inflicted, and usually because of trying to save a buck or two.
Whoever sold you your gear should be able to help you with it.
There are plenty of official stockists listed and many skilled installlers.
That is the place to start.
Coming onto a community forum to have a moan isn't going to get your issues solved.
Was genau ist aktuell dein Problem?
Ich habe mir mal deine anderen Fragen angeschaut und in keinem hast du mal genau den Aufbau und die Konfiguration deines Systems gezeigt, immer nur Screenshots von Diagrammen aus dem VRM Portal.
Einiges macht für mich auch den Eindruck das Spannung, Strom und das ohmsche Gesetzt doch nicht so klar sind bzw. du dich nicht ausreichend mit der Victron Software (VE.config) und dessen Möglichkeiten befasst hast. (AC Eingangsstrom vs. DC Spannung oder "was sind Assistenten?")
Die Möglichkeiten zur Nutzung der Victron Komponenten und derer Programmierung sind so umfangreich, da ist es schwer bis unmöglich ein Konfigurator, wie du ihn vorschlägst, umzusetzen. Zudem bietet Victron im Grunde ja auch keinen direkten Endkunden-Support sondern das läuft alles über das Distributorennetzwerk.
Für viele Sachen gibt es aber dennoch von Victron umfangreiche Dokumentationen, leider zum größten Teil nur Englisch.
https://www.victronenergy.com/live/ess:start
https://www.victronenergy.com/media/pg/Energy_Storage_System/de/index-de.html
https://www.victronenergy.com/live/battery_compatibility:pylontech_phantom
Wenn du vor dem Kauf der Komponenten dem Händler erklärst, was du vorhast, sollte dieser dir auch bei der Auswahl und Konfiguration der Komponenten helfen können.
Nichts gegen dich persönlich, aber wir haben einige Kunden die sich Elektrotechniker oder Elektroingenieur nennen und die haben oft die meisten Probleme ihre Anlagen selbst zu konfigurieren.
Warum nutzt du z.b. nicht einfach den ESS Assistenten (oben verlinkt)? Der würde vermutlich genau das machen, was du willst und funktioniert wunderbar. (MultiPlus-II vorausgesetzt und Anlage muss beim Energieversorger angemeldet werden!)
Ich würde also vorschlagen bevor du weiter auf Victron schimpfst, erstellst du noch eine neue Frage in der du erstmal erklärst, was für Komponenten du hast, was das System machen soll, wie es angeschlossen ist und wie es aktuell konfiguriert ist. Danach kann man diskutieren was man wo wie ändern müsste/könnte, damit das System so läuft wie du dir das vorstellst.
Stephan Zillikens answered ·
Mein Problem ist die mangelnde Transparenz des Sytems, ich verstehe das Konzept der vielen verschiedenen Busse und Tools nicht. Und warum übernimmt der MultiPlus II die Einstellungen des BMS nicht.
Mein Ziel: Eine Solaranlage MPPT150/35 läd eine Pylontech -Batterie auf. Ein Multiplus II versorgt mein Haus aus dieser Batterie mit (fast) allen Verbrauchern solange, bis die Batterie auf SOC 30% entladen ist, dann soll der MultiPlusII das Netz durchschalten, bis SOC der Batterie (ausschließlich über die Solaranlage geladen) wieder auf 40% angestiegen ist, dann soll der WR wieder aktiv werden.
Ich denke, dies ist eine Standard-Applikation.
Ich habe das BMS der Pylontech aktiviert. Das Laden der Batterie funktioniert. Nicht nachvollziehbar sind immer wieder Stromabschaltungen, sehr zum Ärger meiner Frau, die mir dann Vorwürfe macht...
Heute habe ich, nachdem ich meinen (hoffentlich auch teilweise konstruktiven) Frust formuliert habe, das erste mal die Vermutung gehabt, dass das BMS der Pylontech-Batterie nur den MPPT beeinflusst. Aber der MultiPlusII ist überhaupt nicht mit dem BMS verbunden, auch wenn er, wie die Batterie, mit dem Cerbo verbunden ist.
Über MK3 mit dem MultiplusII und VE-konfigure verbunden, vermute ich jetzt, dass der VS die Schaltstelle für den Ärger ist. Die Erklärungen, wie der VS funktioniert, sind für mich so formuliert, dass man sie nur versteht, wenn man schon weiß, wie er funktioniert . Da ich selber schon öfters Bedienungsanleitungen geschrieben habe, kenne ich auch das Problem. Die eigene Beschreibung eines Systems, dass ich selbst entwickelt habe, versteht noch lange nicht jeder.
Und an dieser Stelle macht es Sinn, die Systemvorschläge, die ich gemacht habe, ganz konkret in Einstellungen z.B. für den VS umzusetzten, oder man fragt einen DAU wie mich, ob die Formulierungen in der Hilfe wirklich eine Hilfe sind.
Ich habe die Hoffnung noch nicht aufgegeben.
https://professional.victronenergy.com/online-training/
(kostenloser Account nötig)
Das ist keine wirkliche Standard Konfiguration, Standard für so eine Anwendung wäre ESS.
In der aktuellen Konfiguration interessiert den Multi die Batterie nicht, das einzige, was er davon übernimmt, ist der SOC.
