Hello.
I'm updating the boat system with
MultiPlus-II 12/3000/120-50 2x120V.
I have two AC main sockets installed, each 30 amp and wired to the two different loads. One is supply for AirConditioner and water-maker. Battery charger, water heater, and hose sockets on the second circuit.
The question is How can I combine two AC-in? Should I use the second 30amp source as the third phase on inverter AC-in?
