grasshouse avatar image
grasshouse asked
12v 100a only charging 95%
First charge 100%
second charge starting at 43% but after 18hrs charging the battery only shows 95% when the 12v30a (3) ip22 is in the storage mode
Is this normal- I’ve read that fully charging lithium ion to 100% isn’t good anyway
Is this a limit for the lithium battery mode or should I be getting 100% on my battery
bluesmart ip22
Alexandra avatar image
Alexandra answered ·
@Grasshouse
Storage mode is a lower voltage than bulk/absorption and float. So technically it is at a lower soc.
Is the soc coming from the battery?
It should have reached 100% during or at the end of the absorption phase in the charge cycle, then the voltage would have dropped back down again.
Fyi when the battery is at 100% the cells are not at 100% of their full potential. The manufacturer of the bms has made sure you are not using the full voltage range of the installed cells. So as an end user the 100% issue is not really something to stress about.
You do however need to make sure it is top end balancing by getting to the bulk/absorption voltage that is recommended by the manufacturer
