orca6 avatar image
orca6 asked
User Interface customization
Hi everbody
I would like to customize the User Interface of a GX Cerbo / Touch 70 so that I can replace / enhance the control panell of my RV (Niesmann & Bischoff Clou).
The User Interface should in particular allow for switching of/on the water pump in the RV without having to schroll through the menue. Same goes for the motor pre-heating via the heating system of the RV.
The Components consist of a MPTT Charger, Orion B2B charger, Smart Shunt, 4 Temperature Sensors and Multiplus. This is networked via a Cerbo GX and Touch 70.
In addition it would be very handy to read out some temeperatures (fridge, outside / inside temperature) and configure triggers / alarms in so far certain thersholds are met.
Reading here, I get the impression that the realisation of my "wishlist" should be feasible.
I would be gratefull for hints / advice of alike solution or a guide for "dummies" that eases a beginner (like me) to endevour a customized User Interface.
Best Regards
Martin
Venus OS
pau1phi11ips avatar image
pau1phi11ips answered ·
This guy has done some heavy customisation. Prob a good place to start:
https://community.victronenergy.com/idea/105909/guimods2-replaces-guimods.html
Kevin Windrem avatar image Kevin Windrem commented ·
I did add a really overview that brings relay control to help make manual on/off control easier. Cerbo has two relays. The first can be programmed to turn on a pump based on a tank level. The other is manual on/off only.
Here is a link to my mods:
https://github.com/kwindrem/GuiMods2
Cerbo has 4 temperature inputs and Victron sells a compatible temperature sensor or you can use LM335 IC. As far as I know, there are no triggers that can be linked to these. I don’t recall if there are any alarms but might be.
pau1phi11ips avatar image pau1phi11ips Kevin Windrem commented ·
Adding temperature relay control is in development within the main Venus OS.
This guy got it working though: https://community.victronenergy.com/questions/57187/curbo-gx-temperature-activation-of-relay.html?childToView=63248#comment-63248
I want to use it add control of some battery heaters to keep my LiFePO4 above 5°C.
