I have a system which needs 44 LFP 25.6 / 200 Ah (22 string), Can I built this system by using Victron LFP ?
It is in the datasheet:
https://www.victronenergy.com/upload/documents/Datasheet-12,8-&-25,6-Volt-lithium-iron-phosphate-batteries-Smart-EN.pdf
For such a big system I would not use the Victron batteries, they are way to expensive for that.
Other manufactures have a better price/kWh.
https://www.victronenergy.com/live/battery_compatibility:start
23 People are following this question.
Magnum MSH 3012RV with Victron 12.8V Lithium Battery
Discharge voltage of LFP Smart 12.8 V 200 Ah batteries
LFP Smart Battery 330Ah much smaller than 300Ah?
Can I combine EasySolar 24/1600/40 all-in-one with one Victron LFPSmart 25,6/100 battery ?
Victron LFP Smart 200 Battery upgrade and integration with Redarc Manager 30 BMS System?
