colins avatar image
colins asked
Latest VE.Configure failure/bug??? when using Remote VEConfigure.
When attempting to use Remote VE.Configure (90.04.228), at the point when we update/load Assistants we get the following message: "Internal Error Occurred - Please Contact Victron Energy"
We're unable to use the program. Would the previous version be available to download anywhere? We have 30 sites to update remotely so would appreciate any advice/help - thanks
VEConfigure 3
jpasop (Victron Energy Staff) avatar image
jpasop (Victron Energy Staff) answered ·
@ColinS Please try the following to correct the VEConfigure problem.
Check if the directory:
C:\Users\<USERNAME>\AppData\Local\VirtualStore\ProgramData\VE Configure tools\
exists.
If so then this is likely causing the issue.
Please delete the directory "VE Configure tools" from this spot and restart VEConfigure.
The problem should be solved then.
(Note that the AppData folder is hidden by default. So you might have to unhide them first through your File Explorer view settings)
colins avatar image colins commented ·
That worked. In addition to the above steps, I opened VE.Config, selected a Fake Target with full options, went to the Assistant Tools tab and selected Repair assistant installation. This downloaded and fixed all assistants. All is working perfectly now - Thank you!
Hi @ColinS thank you for reporting. We’re looking into this and will contact you if necessary.
Not that it helps you, but perhaps anyone else reading this: on all our test systems it works well; just like it did before the release.
best regards, Matthijs
JohnC avatar image
JohnC answered ·
Hi @ColinS
Interesting it happened when uploading assistants. I just took a look at VEConfig and it wanted to update. I declined but then it threw this..
1635773766422.pngMaybe you could try a reinstall?
