oskaratk avatar image
oskaratk asked
charger for possibly deep discharged battery
I am looking for a charger that
- can recharge a deep discharged battery AND can be remotely monitored.
Looking at the Victron chargers, the Blue Smart IP67 would match the "deep discharged" - but it has Bluetooth only, so no remote monitoring
On the Phoenix Smart IP43 series I cannot find info about deeply discharged batteries ...
The solution is for a remote telco system ( wireless internet service ) .. so I'd rather deep discharge before interrupting critical service
Any hits are highly welcome
Oskar
charger
@oskaratk
You could add a bmv, use the relay to switch on or off the powerpoint for the ip67. Add a gx then you can monitor if it is charging etc using the bmv.
oskaratk avatar image oskaratk Alexandra ♦ commented ·
@Alexandra
just to be sure I get it right:
With a BMV-712, I'll get Bluetooth comms between the IP67, the BMV-712 and then VE-Direct to the GX ?
Alexandra avatar image Alexandra ♦ oskaratk commented ·
No direct comms to the charger, but you will see if it is receiving, or needs a charge using the bmv through with a ve direct to the gx.
The bmv relay just switches on a contactor for a power point that switches on the charger if it is needed on the side.
