rcox avatar image
rcox asked
Ceiling Mount of MultiPlus Compact 12/2000/80 in RV Storage Bay
I'm considering mounting a MultiPlus Compact 12/2000/80 on the ceiling of a RV Storage Bay using 1/4" machine screws and threaded into t-nuts through a sheet of 3/4" marine grade plywood in the storage bay. Is there any problem mounting the enclosure in this orientation? Other than reduced cooling efficiency, is there any concerns? If so, what's the concerns?
