Hello!
I would like to connect a simple on / off switch to the cable of the dongle in order to be able to switch off the Bluetooth signal. Is it that easy? Which cable? The Red one? Or both, electricity and ground?
Thanks in advance...
Hello!
Hello @simran707
The pinout of the connector can be found in the "VE.Direct Protocol" document that can be downloaded from here: https://www.victronenergy.com/support-and-downloads/technical-information
To turn off the bluetooth dongle, switching the Power+ should be enough.
Kind regards,
Thiemo van Engelen
23 People are following this question.
