gregp avatar image
gregp asked
BVM 702 not connecting with IPhone
Just bought a new 2021 trailer with a BMV 702 battery monitor, I have an I phone 11 with version14.8. Have down loaded the Victronconnect app all goes well until 95% when it just sits and spins. Have tried all of the suggestions in the manual, recycled power to the unit, made sure I was accessing unit thru the app and not blue tooth, and have restarted the phone. Still no pairing. Any help would be greatly appreciated!
BMV Battery Monitor
Hi @Gregp
Can you please make a service report of the connection attempt and attach that to a reply or comment here?
The procedure for making a service report is described here: https://ve3.nl/VictronConnect_How-to-create-a-VictronConnect-Service-Report
Kind regards,
Thiemo van Engelen
powerace avatar image
powerace answered ·
I think it is only the BMV-712 that has Bluetooth. The BMV-702 is a unit without Bluetooth so you can't pair at all. Please check the specs of the unit.
gregp avatar image
gregp answered ·
Interesting as it shows up as a selectable device on the app and the phone Bluetooth recognizes it too. So am thinking it is Bluetooth compatible?
nickdb avatar image
nickdb answered ·
For bluetooth access it needs a smart dongle.
It has a VE port to connect to the GX, so it will appear as a device via the VRM tab but direct (local) access will need the blueteeth smart dongle.
https://www.victronenergy.com/upload/documents/Datasheet-BMV-700-series-EN.pdf
