wdeertz avatar image
wdeertz asked
How to set superuser without Control GX?
I recently installed a Cerbo GX with a few temperature sensors. I need to adjust the offset on the temperature probes but the manual says I need superuser access. I found the instructions to set the superuser access but it says it only works from a Control GX screen. I am access the remote console via my laptop. Is there anyway to setup for superuser access without a screen?
setup
seb71 avatar image
seb71 answered ·
You do not need the display for this.
wdeertz avatar image wdeertz commented ·
ok do you care to share how to do this? The link I found said that from the control panel you need to hold the right arrow down while on user access but the mouse click does not work. Please share how I can grant superuser access from the remote console. Thanks
seb71 avatar image
seb71 answered ·
You did not link which guide you read.
If this is the guide you read, then at step 4 it has the following note:
Note: when working from the Remote Console, you need to use the right key on your keyboard. Pressing and holding the right button with your mouse won't work.
Thanks, the posting I reviewed didn't mention the right arrow key on the keyboard. Thanks that solved my problem.
jeroen avatar image
jeroen answered ·
Just hold the right arrow in the hotkeys (at the right).
Harald Schweiger avatar image
Harald Schweiger answered ·
Had the same problem with adjusting temp. sensors but how can I go back from Superuser mode ?
Since this time my energy meter EM540 do not work as it should.
If I change to User or User + Installer it want to know a pasword, but there was never one generated
No chance to go out of this mode. Maybe reset Cerbo GX to factory settings
Next try: I load an older Cerbo GX firmware from SD Card. Same issue.
Thanks for helpful ideas
Harald
