johnny-brusevold avatar image
Node Red pi and sms
Runs Venus Os large latest version on a raspberry pi 3b, which works quite well. Want to configure more options for other components, something I hope can be done with node red.
I'm not very good at such things, but have got something working, like meters and the relay in BMV-712.
I'm offgrid full time in a camper, so the rasberry pi is wired to a tplink lte 4G router.
Have installed some software on pi so I can send sms via ssh to tp-link integrated sms app
The real question is, can one connect this via node red so I can send alarms to my mobile phone?
command to send sms
./sms-send.js --url = "http://192.168.1.1" --login = "admin" --password = "myrouterpassword" "0612345678" "my text message"
Maybe I'm looking at the wrong end so it's nice if someone can put me in the right direction
Node-RED
mrhappy avatar image
mrhappy answered ·
Hi @Johnny Brusevold,
I believe this is very doable.
There is a node which will execute a command within the Raspi itself, the red "exec" node. Instructions here: http://stevesnoderedguide.com/using-the-exec-node
Or,via settings - "manage palette" you can install the "exec big" -node, just an alternative to it. Description here: https://flows.nodered.org/node/node-red-contrib-bigexec
/MrHappy
Thank you for your answer.
This seems interesting
When I look at software that is used to send sms, it is based on nodejs and yarn.
Maybe it is possible to integrate it in node red, but I know too little about this.
Anyway, I attach the link here if anyone should be interested in this
https://github.com/plewin/tp-link-modem-router/
exec big worked great.
Failed to get node-red exec a .js file, so had to run through a bash script.
Have only tested with over volt alarm with input from BMV-712 Smart, and it works as desired
