baileyscott avatar image
baileyscott asked
Venus OS install tcpdump
Anyone know how I can install tcpdump on my Victron CCGX running VenusOS.
I've tried with opkg install <localfile> but it keeps failing with "does not have a compatible architecture".
I think I've tried every variant of processor architecture that exists!
Any ideas?
CCGX Color Control
nickdb avatar image
nickdb answered ·
Isn't the CCGX an einstein board? You would need something compatible with the embedded architecture, I am sure someone here can confirm.
jeroen avatar image jeroen ♦ commented ·
I can confirm it is not an Einstein board.
jeroen avatar image
jeroen answered ·
This should do the job:
/opt/victronenergy/swupdate-scripts/resize2fs.sh
# Note: the next line is only needed when not running a release, candidate is just an example. It should match with the firmware kind you are running.
/opt/victronenergy/swupdate-scripts/set-feed.sh candidate
opkg update
opkg install tcpdump
The architecture doesn't matter, the device will know it itself. It is a cortexa8 in case you wonder.
baileyscott avatar image baileyscott commented ·
Thanks @Jeroen. I persevered with this and eventually found that I had to install from ......
https://updates.victronenergy.com/feeds/venus/release/packages/zeus/cortexa8hf-neon/
I managed to get tcpdump and it's dependencies.
jeroen avatar image jeroen ♦ baileyscott commented ·
yes, but if you use the package manager (opkg), you don't have to care where it is downloaded from. It will just get installed if you ask for it.
