brian422 avatar image
brian422 asked
Victron Phoenix Multiplus 12/3000/120 Setup.
Victron Energy Phoenix Multiplus 12V/3000VA/120A, V.E. Bus Multi Controller, Victron Battery Monitor.
I would be grateful for advice regarding setup because according to Victron
All DIP switches are OFF position; does this indicate system has been configured using V.E. Bus ?
My Laptop has a LAN Cable connection; will a Lan Cable be sufficient to communicate with Multiplus or will I require additional interface?
Regards and Thanks
Brian.
VEConfigure 3
If it is an old Phoenix MultiPlus than you need a MK2 Interface (ASS030130010).
brian422 answered ·
Hi Matthias. Thanks for reply.
Assume your reply, because all DIP switches in OFF position, unit was programmed via V.E Bus.
Narrowboat built 2009. Phoenix Multiplus has e13 032428 printed on case.
Do I still need Mk2 Interface?
Regards and Thanks.
