Vangelis Beligiannis avatar image
Vangelis Beligiannis asked
Quattro does not comply with VDE 0126...
It is obvious that a Quattro does not comply to the VDE 0126. Is there any anti islanding protocol that it complies with? I am trying to install a system in the Greek public grid, but the device will not be accepted anywhere in the country without an anti islanding protocol
shaneyake avatar image shaneyake commented ·
Can you explain a little bit more about why it doesn't comply? As it has a VDE 0126 certificate?
Vangelis Beligiannis answered ·
So you Just verified what i said from the beggining. The Quattro does not comply with the VDE 0126. There is no current sensor on ac in to read the grid failiure
It seems to be Quattro model dependant - is yours one of the models listed by nickdb? The rest probably don't comply. So you'll need to go with Matthias Lange's suggestion.
Vangelis Beligiannis avatar image Vangelis Beligiannis kevgermany ♦♦ commented ·
From what i know, the Quattro has always had the same schematic diagramm. Differences only exist for the Multiplus. So all Quattro s are the same
kevgermany avatar image kevgermany ♦♦ Vangelis Beligiannis commented ·
Odd that some have a certificate and that some don't. Must be that they're not all the same.
nickdb avatar image
nickdb answered ·
6 comments
Vangelis Beligiannis avatar image Vangelis Beligiannis commented ·
Thank you for sending that! But in the VE config droplist, there is no option for FRANCE VDE0126. This only appears on the Multiplus droplist and not on a quattro. Any ideas why?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Vangelis Beligiannis commented ·
You may have to install an external anti-islanding relay.
The Ziehl UFR1001E for example.
nickdb avatar image nickdb ♦♦ Matthias Lange - DE ♦ commented ·
How would the quattro have received compliance certification if a third party device is required?
Vangelis Beligiannis avatar image Vangelis Beligiannis Matthias Lange - DE ♦ commented ·
I also cannot find a Certificate for VDE 0126 for a Multiplus II in the website. Is it available?
seb71 avatar image seb71 Vangelis Beligiannis commented ·
Multiplus II - 2 relays (in series) on AC In:
Quattro - only one relay on (each) AC In:
