bigbadbob76 avatar image
bigbadbob76 asked
Low battery warning settings.
Hi. can anyone confirm that "DC input pre-alarm" setting on multiplus is the level at which VRM triggers a "low battery warning" when configured to do so?
I want to recieve a warning when my batteries reach 50% DoD but not shutdown the inverter..
I use a BVF300 (non victron) board to turn off my loads at 75% DoD but that does not report to the multiplus so I can't get VRM alarms from it.
bigbadbob76 answered ·
Thanks Alexandra. :-)
I'd missed the ve bus soc option in alarm rules.
all sorted now.
Alexandra avatar image
Alexandra answered ·
@Bigbadbob76
You dont need a device to do this you can set up an alarm using the vrm itself.
Sertings - alarm rules.....add new alarm rule.
Select the device (ve bus soc, bmv) and set where you want the alarm to start and clear.
