Rob Beckers avatar image
Rob Beckers asked
MultiPlus 3000 bricked during failed firmware update
One of our customers tried updating the firmware of his Multiplus 12/3000 using (initially) VictronConnect and an MK3-USB. This failed halfway, and since then the inverter will show all LEDs flashing when switched on. He tried redoing the update with VE.Configure to no avail, at this point the MK3 won't even see the inverter any more.
I've read through all the posts on this forum that describe a similar issue, but none seem to have a solution for my customer's dilemma.
Is there a way to get the inverter to revert to an older firmware, so we can get it to communicate again? Any other suggestions to recover from this?
Thank you!
-Rob-
Solacity Inc.
firmware update
Rob Beckers answered ·
The customer reported this morning that the update via VE.Flash worked very well (via his MK3-USB), and the inverter is once again up & running. So this is definitely the way to go when a firmware update goes wrong.
Thanks again Matthias!
-Rob-
Solacity Inc.
