This looks like it might be the maximum value for these sensors (about 5 volts which I think is the supply for the pull-up. So you need to connect a working temperature sensor. Victron sells this as ASS000001000. It will not work with the Victron ASS000100000 which is designed to work with BMV/SmartShunt.
You should also set charge limits for the battery gauge. And not sure what's going on with the PV charger gauge. See the ReadMe for GuiMods for gauge setup instructions.
Kevin thank you so much for your advice. I have pasted the new screen with the gauges set but I have a problem with my T sense being connected to my Multi, every time I connect it I get an alarm about the T-sense error. This has done this since new so I left it disconnected. I have the SmartBattery Sense stuck to my battery so I thought it would get the temp from that. I don't know what to do to fix it. Do I need a new T-sense for the Multi?
T-sense alarm when I connect it to my Multi.
Never mind with my last question, I got it working by dis-connecting the T-sense from the Multi and connected it to my Cerbo. It is working now. Thanks again for all the help!
24 People are following this question.
