vfrjim avatar image
vfrjim asked
MPPT 75/15 float issue
Randomly at times, my charge controller says it is in float mode but is not maintaining the set float voltage of 14.6 volts that I have set in the custom battery configuration, I come back and notice it is sitting at 14.4 volts and I then start applying a load on my batteries and expect the charge controller to start increasing the float charge but it does not. I then have to reboot the controller and then it goes back into absorb mode, not that I want it to go back into absorb mode but just want it to keep the batteries in float mode. Is there a problem?
Thanks
MPPT Controllers
boekel avatar image
boekel answered ·
what voltages does it reach? is there enough solar power to maintain float voltage?
