maxence-pichon avatar image
maxence-pichon asked
Method to reduce VenusGX and BMV 700 power consumption?
Hi
I am making some tests using a small off-grid solar system equipped with batteries and the following Vitron's products:
-BlueSolar charge controller MPPT100 30
-BMV Battery Monitor
-Venus GX
Venus GX power consumption is supposed to be 12V 210mA.
How do you think power consumption would be reduced if I disable the Wifi Access Point?
Do you see other option what I could change to reduce power consumption, even by a few mA?
Many thanks
BMV Battery MonitorVenus GX - VGX
gro avatar image
gro answered ·
You can try it for yourself
maxence-pichon avatar image maxence-pichon commented ·
Before trying to disable Wifi Access Point I'd like to know if there is anything else I should try.
