antjam avatar image
antjam asked
SmartSolar MPPT 100/20 Minimum Vmp?
Good day,
I have a single panel with the following specs:
Pmax: 260W
Voc: 38.4V
Vmp: 30.72V
Imp: 8.47A
I am looking to get a SmartSolar MPPT 100/20 charge controller to charge a single 12v 100A Gel battery for my caravan. I was told by the technical support chap at the local distributor that the Vmp of 30.72V is too low for the MPPT charger to work effectively at charging a 12V battery and that I would require a Vmp of at least 60 - 70V to make the SmartSolar 100/20 work efficiently - is this correct?
MPPT Controllers
Mark avatar image
Mark answered ·
I disagree & think that it would work fine - there is a reasonable 'buffer'.
The Voc is more relavent in relation to the MPPT 'wake up' that is Vbatt +5v & it's a fair amount higher (about 20v higher).
Yes higher voltage would be a tad better but there should be no issues with your proposal.
wkirby avatar image
wkirby answered ·
I agree with Mark.
That is a perfectly acceptable Vmp for a 12V system Voltage.
I don't know why your distributor told you that. He'd be right if your system Voltage was 24V.
