jc-alacoque avatar image
jc-alacoque asked
MPPT 250/100
12 X 100W panels in series/parallel on roof of motorhome. 12V batt bank. Inside the shop with ceiling lights on, the PV open voltage is showing 75V. But when I connect it to the controller, it drops to 12.5V. The batteries are at 12.6V. Should it not be able to charge the batts ? Thanks.
battery charging
@JC Alacoque
Check your polarity?
Do you have a smart product?
jc-alacoque answered ·
Polarity is right. Smart product? The controller is a Victron MPPT 250/100, if that is what you mean. Just panels to controller to batteries.
The mppts came in different flavours. On the mppt it will say SMART or not, as part of the branding.
Alan avatar image
Alan answered ·
Your shop lights will trigger some voltage, but not enough energy to drive output from the panels.
If you took a 100W bulb, and 20% of it's total output landed on the panels, which are 20% efficient, that's 100W x 0.2 x 0.2 = 4W. That's not entirely accurate, but you see where it's heading.
