ancanc avatar image
ancanc asked
Installing a MultiPlus-II 12 | 3000 | 120-32 - Remote Swich and horizontal Installation Position
Hi, i am new here - first post, first questions...
Installing a Multiplus-II 12/3000/120-32 on a Sailboat. I do not have a MultiControl panel and would like to use a "Remote Switch" on terminal "M". In the manual found two statements:
3.2 Remote control
Remote control is possible with either a switch or with a Multi Control panel.
and in Appendix A:
M Connector for remote switch: Short to switch “on”.
Is it possible to switch the unit to “charger only” mode with the remote switch (Connector M) , if yes how?
2,
The ‘Quick Installation Guide’ shows only a vertical installation position of the unit.
Is this the only valid position how the unit can be installed or are other positions also allowed if the ventilation still provided?
Thanks,
Regards:
Andras
Multiplus-II
