vansailor avatar image
vansailor asked
BMV-602S to BMV-712
Hello, I am going to replace my boat's battery monitor BMV-602S with a BMV-712. I am wondering if I can use the existing 602's shunt with the new 712 monitor? It would save a lot of work installing if I don't have to replace the existing shunt as it is difficult to access.
Thanks
BMV Battery Monitor
wkirby avatar image
wkirby answered ·
I have just switched out a BMV-600 with a BMV-712 using the existing shunt cable, so I would think that the same would be true for a BMV-602.
The data connector is different between the two though, but that may not be important to you.
vansailor answered ·
Hi, thanks for the replies. Sorry but I'm not sure what you mean by the "data connector"? Thanks
