ccanupii avatar image
ccanupii asked
Wiring 12/3000/120 AC In
The Load panel has a switch for either Shore (2 lines - line1 main load, line 2 three a/c units) or Generator and currently a breaker to power the current charger. I have two battery banks, 4 house batteries and three starter batteries. I am putting the 4 house batteries to the primary battery terminal and the three starter batteries to an Argo FET 3 to 1 which will be wired to the secondary (trickle) terminal. Can I wire the AC 1 out to the generator switch to provide inverter power to the load panel? AND could I then wire the programmable switch to the generator start switch and program to auto start at a low wattage point? Literature says that the AC 1 out is bypassed when the generator/shore is available. Does this sound right to anyone or wrong to everyone?
wiring
Trevor Bird avatar image
Trevor Bird answered ·
Hello, Is the Victron unit a Multiplus or a Quattro?
